Examine the Example
Let's examine some pieces of the example module to see how they interact to create a scripting function.
This is not an exhaustive list of every file or class required to make this example work. We encourage you to examine the other directories included in this example project to see how they all fit together.
common
The common
directory defines the interface and abstract class that all the implementing functions must adhere to, regardless of scope. This directory contains the files that define the function itself:
AbstractScriptModule.java
MathBlackBox.java
The AbstractScriptModule
class defines the function and its arguments:
@ScriptFunction(docBundlePrefix = "AbstractScriptModule")
public int multiply(@ScriptArg("arg0") int arg0,
@ScriptArg("arg1") int arg1) {
return multiplyImpl(arg0, arg1);
MathBlackBox
implements the abstract class MathBlackBox
to provide the math behind the multiply()
scripting function:
package com.inductiveautomation.ignition.examples.scripting.common;
public interface MathBlackBox {
public int multiply(int arg0, int arg1);
ClientScriptModule
An instance of ClientScriptModule
is used in the Designer and Client scope to provide details about the function. The ClientScriptModule
class creates the actual RPC handler, using the API's ModuleRPCFactory.create()
method:
public ClientScriptModule() {
rpc = ModuleRPCFactory.create(
"com.inductiveautomation.ignition.examples.scripting.ScriptingFunctionG",
MathBlackBox.class
The ModuleRPCFactory
handles passing values back and forth between scopes.
GatewayScriptModule
When executed, the ModuleRPCFactory
will automatically call the GatewayHook
's getRPCHandler
method, which
returns the GatewayScriptModule
with the actual implementation of MathBlackBox
package com.inductiveautomation.ignition.examples.scripting.gateway;
import com.inductiveautomation.ignition.examples.scripting.common.AbstractScriptModule;
public class GatewayScriptModule extends AbstractScriptModule {
@Override
protected int multiplyImpl(int arg0, int arg1) {
return arg0 * arg1;
